Fork Tight In Triple Clamps
Posted: Mon Dec 14, 2020 2:00 pm
Hello All - First Post
I have what I believe is a heavily modified ACE 100 based on frame and engine numbers. I've got a couple things in progress, but I'd like some thoughts on the fork being tight in the triple clamps. The fork is Cerani and might be a thing of the past eventually due to pitting, but for now I would like them in place as I'm sorting out cleaning up and greasing the the triple clamps, front wheel and all.
The tubes are a bear to get in and out of the triple clamps. The triple clamp suggest a little adjustability via the grooves, but every thing I've tried has not yielded much in the way of give and I don't want to get too heavy handed. Obviously I don't want the tubes going in loose, but it would be nice if they weren't difficult to get in as they are. The triple clamp nuts were completely out when inserting and removing tubes, couple pictures don't reflect that.
So is there any adjustability to the triple clamps as far as loosening up to make the tubes go in with reasonable effort. Only other thing I could think of is tubes are not straight, I think they are, I could disassemble and check? I've smoothed the pitting and don't think that's it. I did have the triple clamps loose so they wouldn't be a bind opportunity? Oh and they are not hanging up on the caps
Also any crossover, different make, model or brand as far as eventual fork replacement?
Appreciate any input.
Thank You
PS - Post more about the whole bike soon. It in tough shape, but lots of mods - back in the day aftermarket on it. I get the impression maybe somebody's old race enduro? That or just well prepped.
Thank You
