32mm Ceriani Front End
Dal Aymond
Post by Dal Aymond »
I have come in to possession of a couple of complete 32mm Ceriani Front Ends. One is from a Penton. I'd like to mount one of them on my Combat Wombat. Any advice, information, or instruction would be appreciated. Thanks.
Re: 32mm Ceriani Front End
That is an impossible fitment without destroying the entire geometry, balance, AND value of the bike so I'd give up on the idea. They are junk anyway. Don't toss 'em, though. I get 10 cents apiece for them at my metal scrapper so just send them to me and I will see to it that they are properly 'recycled'. I'm helpful that way. :)
Dal Aymond
Larry S
Post by Larry S »
I put 32mm Penton Ceriani forks on my Ace 100B. It was a direct bolt on. I had to make new stops to keep the forks from hitting the tank. The Penton trees are wider than the Hodakas so you need the Penton axle. I'm sure the CW would be similar.
Larry S
Dal Aymond
Larry S wrote: Fri Oct 16, 2020 4:08 am I put 32mm Penton Ceriani forks on my Ace 100B. It was a direct bolt on. I had to make new stops to keep the forks from hitting the tank. The Penton trees are wider than the Hodakas so you need the Penton axle. I'm sure the CW would be similar.
Larry S
Thank you, Larry S. I'll give it a try.
I have a Wombat frame with Cerianis on it, which I just recently acquired. I didn’t do the installation, but I can certainly provide pictures for you. Let me know! :ugeek: Victor
