Race Hodaka Wombat
Race Hodaka Wombat
Do any of you guys and gals race your Wombat 125, in Vintage Motocross or Vintage Cross Country? Do you recommend any changes or upgrades?
Re: Race Hodaka Wombat
Dal,
I raced my M94 Wombat in VMX a few years ago. It's completely stock, all I did was remove the lights, battery, kickstand, unplug the ignition switch (so I didn't need to worry about a key), added some number plates and covered a few bit's with fuel hose. Here's a link to the thread that tells the story:
http://hodakaforum.com/viewtopic.php?f= ... hey#p24895
In hindsight, the only thing I would have done different was change to knobbys. I was running some Shinko enduro tires and they slid all over the dewy grass in the morning practices. Later in the day as the course was run dried and compacted, they slid all over that too.
All in all it was a blast and I look forward to giving it another try.
Bev
Bev
'72 Wombat (94)
'65 ACE 90? (Frame)
'66 Triumph Bonneville
'99 Triumph Adventurer
'66 Ace 90/100- Dirt only
'65 ACE 90? (Frame)
I would suggest some suspension upgrades. At least rear shocks and a front fork brace are advisable if the type of racing you are considering has any gnarly terrain or jumps. Beyond that, in my opinion, conversion to reed induction pays great dividends in either discipline, although you need to consider that reeds will take you out of the "classic class" in any AHRMA event. One could argue that reed conversion is the best single performance upgrade you can do. Better top end on an MX track, and better low gear grunt for woods racing with the usual hills to contend with. If you want to keep the motor with piston port induction, a little mild port work is good to consider.
Thank you, TheBevman, for your post.
Thank you, Matt glascock, for your post. I will be riding in the AHRMA 60+ Novice Vintage Cross Country Class, so if I go with reed valves, I'll still be ok.
You will appreciate the reeds in the woods for sure. Low end torque-age is a must for low speed grunt, quick, controllable acceleration on a tight single-track woods course and hill climbing.
