01 forks
01 forks
One dust wiper is badly cracked, and the other is not far behind. Seals and o-rings are probably in similar shape. Interestingly, the forks work perfectly and have as good damping as my recently rebuild (by Hodaka Dave) RT forks. I have never worked on painted tank model forks other than some relatively fruitless oil mixing experiments looking for a dual-purpose wonder brew. I'm flirting with the notion of changing the wipers and oil and running them as is (if the oil is funky, rebuild). Any tips/caveats to know about before I whip out the Dremel and dig in. I'm reasonably confident with toaster tank forks and am armed with legit workshop manuals.
Re: 01 forks
Get the fork caps and the outer nuts were the seal sits loose, do the while still on the bike. Kinda using the triple clamp as a vice is better.
Re: 01 forks
href="http://youtu.be/3EUbKp8j09M">youtu.be/3EUbKp8j09M
Re: 01 forks
Thanks Kelly. Just what I was looking for.
