Hodaka ID help
Posted: Wed Jul 01, 2020 12:25 pm
by Cdnhodaka
I just picked up a hodaka and need help identifying it. I was told it was a super rat but I think it may be a hybrid.
Before anyone asks, I've looked for frame and engine numbers. The engine is P70xxx which indicates a dirt squirt, but the frame looks more like a rat or ace, and it's been modified.
It also has a 17 in rear and 19 in front which also leans towards a squirt.
Re: Hodaka ID help
Posted: Wed Jul 01, 2020 7:37 pm
I'd guess you aren't getting much of a response cuz most of us are trying to figure out what to say.
You have a heavily modified "Ace" era Hodaka chassis there. Arrows on the photo point to things which are not "stock".
If you were planning on a fun "rider" - you are on your way. If you were planning on an authentic Super Rat restoration . . . this machine is not a very good starting place.
Re: Hodaka ID help
Posted: Wed Jul 01, 2020 11:46 pm
by Joe Ormonde
Two locations for the Upper Shock Bolt indicates a Dirt Squirt? This is what a Hodaka Fan with several different Models would buy for more parts. WAY too much to do to get it up and running. Still, there is some value to a Hodaka collector. Joe.
Re: Hodaka ID help
Posted: Thu Jul 02, 2020 1:16 am
by Cdnhodaka
I'm aware it's modified. It's going to be a rider not a restore, I have the rest of the engine parts, won't take much to get it running, plus it has a webco head and reed valve induction.
Just asking to make sure I get appropriate chassis parts as needed.
Re: Hodaka ID help
Posted: Thu Jul 02, 2020 2:31 am
I am with ED. It would make the fun rider. I am not sure it is the correct tank, looks different with the front of the gas tank coming to a point could be me eyes?? If you want a superrat get a super rat frame or rolling chasis. I like it, get it running and let er shine. -----------------Clarence
Re: Hodaka ID help
Posted: Thu Jul 02, 2020 3:09 am
by Cdnhodaka
Thanks Clarence, it's definitely not the right tank, it's a skinny plastic one. Looks like it was set up to race and every effort to lose weight was made. Vintage preston petty fenders, and some other things trimmed down.
Re: Hodaka ID help
Posted: Thu Jul 02, 2020 5:02 am
DOH! I missed sticking an arrow on the forward upper shock mount which Joe pointed out - that is an owner mod from back in the day. Size and shape of the steering head gusset (along with other things) confirms the "Ace" era heritage of the frame.
Sounds like it is all going to work out just fine. Cdnhodaka is headed toward making a "rider" and has some interesting engine parts to play with to boot!
Re: Hodaka ID help
Posted: Thu Jul 02, 2020 10:24 am
by rlkarren
It's an Ace 90 frame.
evidenced by the location of the toolbox mount brackets under the seat and the absence of seat mounting brackets which are normally seen through the "big hole" above the extra shock mount. (Ace 90 and Ace 100 seats had different rear mounting brackets.)
$0.02
Re: Hodaka ID help
Posted: Thu Jul 02, 2020 1:30 pm
by Cdnhodaka
That's what I was thinking after checking out various pictures of different models. The seat mount was cut off but the ends are still there and it looks like the one from the 90.
On the rear left side you can see where the early frame number plate was riveted and the coil mount is looks like that of an ace 90 also.
Re: Hodaka ID help
Posted: Thu Jul 02, 2020 2:41 pm
by rlkarren
Cdnhodaka wrote: ↑Thu Jul 02, 2020 1:30 pm
Wait a minute... if it has a coil mount, it cannot be an Ace90 frame. It would be an Ace100 frame. I didn't think that someone would have cut off the mounting brackets for the seat.. silly me...
I'll go hide in my Hodaka shed now...
Re: Hodaka ID help
Posted: Thu Jul 02, 2020 5:11 pm
I didn't see the coil bracket, horn bracket could be? ---------- Clarence
Re: Hodaka ID help
Posted: Thu Jul 02, 2020 6:09 pm
by Cdnhodaka
I'll clarify , it's a 90 frame because there isn't a coil mount. With the coil mount (or absence of one) being a distinguishing feature of the model.
On this particular bike that has a dirt squirt engine someone rigged up the coil to the horn mount.
Re: Hodaka ID help
Posted: Fri Jul 03, 2020 2:29 am
The early rat frame did not have a coil mount either. just to mention. Remote condenser also nice ---------------- Clarence
Re: Hodaka ID help
Posted: Fri Jul 03, 2020 1:47 pm
Cool. Definite race pedigree.
