Removing and replacing the kick starter retaining ring.
I'm not sure if it was on here or on the Hodaka Facebook page, but someone asked how to get the small retaining clip back onto a kick starter lever.
Here are some pictures of how I did it recently.
Basically I took a foot long piece of angle iron and drilled a hole in one side that was larger than the retaining clip, but smaller than the clip retainer. I put the kick starter in a vice with the clip facing up. I placed the hole in the angle iron over the retainer. One one end of the angle iron I slipped a tie down over it and tightened it down. I then placed a ratcheting tie down over the other end. I then ratcheted this one down until it compressed the small spring and levered the clip retainer down and out of the way. With both hands now free, I was able to easily remove the clip. Once done and with the clip re-installed, just release the tie downs.
Re: Removing and replacing the kick starter retaining ring.
Nice! Can you provide the drill bit size you used to make the hole in the angle iron? This would be a good write up for the Resonator Revisited and a good resource for folks who need to perform this repair! :ugeek: Victor
