Greetings
I am building an 03 engine and the only clutch I have available is for a model 99. I'm assuming that the cage for the 03 is deeper and the screws longer to accommodate more clutch plates in the 03 with 4 fiber and 5 steel than the 99 with 3 fiber and 2 steel plates.
If I can't source a correct cage do you think that by adding inner clutch springs, and an additional steel plate would work with the stock 99 clutch setup?
Tom
99 clutch in an 03 engine
Re: 99 clutch in an 03 engine
I have since found two other cages than the 99 cage, In the photo ion the left is a cage for models 98,95,97 which is deep enough for the 5 fiber and 4 steel plates. On the right is a model 03 cage which has room for 4 fiber and 5 steel plates and the middle is a 99 cage which takes 3 fiber and 2 steel plates.
Up until now, I had no idea that there different options...……..always learning something new.
Tom
Tom
