long range projects?
Posted: Fri Apr 03, 2020 4:44 am
by givergas
when you have a project thats going to take a long time to get together for what ever reason. lets say a year or two would it be wise to rebuild the engine and let it sit till you have the bike ready to start, or accumulate all the parts you will need then put it together. i do know that some parts it really doesn't matter. but how would some of you go about this. would really like to know.....albert
Re: long range projects?
Posted: Fri Apr 03, 2020 6:36 am
by thrownchain
If the motor is properly lubed when put together and then stored properly, shouldnt make a difference.
Posted: Fri Apr 03, 2020 7:41 am
I think Thrownchain is correct. At least I sure hope so as I have that situation right now. I use assembly lube on all the gears and transmission bearings and lightly lube the cylinder, rod bearings, piston and rings with my pre-mix oil. I also grease the inner lips of all seals. Even with all this, I still plan to get a frame ready to receive the motor as soon as possible.
Posted: Fri Apr 03, 2020 7:58 am
I always save the motor for last, based on degree of difficulty and the acquisition of parts. If you have a complete rolling chassis, it’s much easier to then rebuild a motor & then drop it in and rest and adjust. Some folks like to do it prior to redoing the chassis. But for me, that usually means doing a lot of things twice. Just my 2 cents.
If I were to rebuild a motor and store it for use later, I would make sure I put good oil in it and turn it over with the kick start every once in awhile so the seals don’t start drying out. :ugeek: Victor
Posted: Fri Apr 03, 2020 11:42 am
by thirdstone
I’ve never used assembly lube on Hodaka Engines but after recently rebuilding later two stroke engines I’m warming to it . Seals themselves will stay fresh on the assembled engines for a long time , a very light smear of grease on the parts they seal against would not hurt . I also think it’s a good idea to turn the engine over by hand every few months .
