Super Rat Chain Guard
Posted: Sun Dec 29, 2019 6:05 pm
Found this on eBay. Just passing it on.... :ugeek: Victor
https://www.ebay.com/itm/HODAKA-1971-vi ... Sw3ZNZ3kpQ
Re: Super Rat Chain Guard
Posted: Sun Dec 29, 2019 6:28 pm
by Tether
Frame No. prefix A makes that an Ace?
Posted: Sun Dec 29, 2019 7:42 pm
Not a super rat chain guard. ----------Clarence
Posted: Mon Dec 30, 2019 4:15 am
OK, then which one is it? :ugeek: Victor
Posted: Mon Dec 30, 2019 4:27 am
The serial number tells you it would be a ace 100B, model number 92B. ----------Clarence
Posted: Mon Dec 30, 2019 4:28 am
by socalhodaka
Not a SR for sure
Posted: Mon Dec 30, 2019 4:31 am
by socalhodaka
I’m going with dirt squirt
Posted: Mon Dec 30, 2019 4:36 am
by socalhodaka
The X pattern on the guard is common with the DS, Wombat and Toad. SR has two parallel lines.
Posted: Mon Dec 30, 2019 4:39 am
by socalhodaka
Posted: Mon Dec 30, 2019 8:24 am
Tabs parts are not mine. The serial number as listed does not fit the model. The ace100B, model 92B and the ace100B, model 92B+ are the long chain guards. Kelly is right again! ------------Clarence .
Posted: Mon Dec 30, 2019 8:55 am
OK so the “X” is the give away! I didn’t know any other Hodaka used a short, red, chain guard. Seems like the DS guard would be a good choice for Aces wanting to run knobby rear tires that would rub on the Ace chain guard! Is the bolt pattern the same as the Ace??? :ugeek: Victor
Posted: Mon Dec 30, 2019 12:35 pm
by socalhodaka
I don’t believe it will swap, maybe with some modification anything can work.
Posted: Mon Dec 30, 2019 12:45 pm
by Bruce Young
You will also note the one with an X on the face of guard has rather square or flat top, the other ones have rounded top. Like Bill said ether one can be made to work with a little back yard engineering. Its the Hodaka way if you don,t or can,t find an original chain cover. Bruce
