Handlebar holder width dimension!
Bobv07662
Post by Bobv07662 »
Can someone measure the dimension of the bolt pattern of the handlebar holder on a Model 92B or 94?
I need width apart ( left to right ) and spread of the bolts in the holder itself, ( center to center ). I'm trying to see if it's the same as a 250ED.
Thanks!
1976 ED250
Re: Handlebar holder width dimension!
Model 92B has the following dimensions:
Width apart inner:2.25”
Width apart outer: 3.5”
Bolts center to center: 2.75”
Space between bolts on one side: 1 3/8”
Handlebar diameter is 7/8”
Hope that helps.
:ugeek: Victor
I did a quick check too and can confirm Victor's information. Bolt centers are 70mm apart side-to-side and 35mm fore-and-aft. I got those measurements on both a Dirt Squirt and my Wombat/Combat Wombat hybrid with Model 03 forks (which are the same as the 250 forks except for spring rate).
Bobv07662
Post by Bobv07662 »
Thank you both for the quick accurate reply. The dimensions you gave match what I measured on my 250ED.
Enjoy Thanksgiving.
1976 ED250
Great! Glad tge Captain provided in mm to my inches! Happy Thanksgiving! :ugeek: Victor
