DPO strikes again
Posted: Mon Oct 21, 2019 9:55 am
by thrownchain
Nut fall off? Weld the sprocket to the shaft...
Re: DPO strikes again
Posted: Mon Oct 21, 2019 10:44 am
Well maybe you can rethread it? My gosh! That’s a shame. Good luck splitting the cases. It should just be aluminum, right???
Posted: Mon Oct 21, 2019 12:03 pm
by swcaudill
The welder did and excellent job. BUT what to do now? I think the DPO enjoyed many enjoyable rides after the questionable repair.
Posted: Mon Oct 21, 2019 1:23 pm
by thrownchain
I got it apart, dremel tool, cutting wheels. Ruined the sprocket and the shaft, i'll just replace the shaft and rebuild. Minor deal, but the lengths some people will go to to keep riding. He most likely never figured to replace the worn sprocket at some point.
Posted: Mon Oct 21, 2019 3:20 pm
No kidding. What if he had worn it down to the tooth nubs???
Posted: Mon Oct 21, 2019 4:40 pm
by Joe Ormonde
Easy! Weld up the teeth and grind them down. That`s how they repair obsolete gears. Joe.
