Condenser Connection
Making sure I’m doing this correctly.
I purchased an aftermarket condenser as recommended in my thread about after market condensers.
The only difference is this condenser has a wire coming off the top instead of a soldering location.
So, if I tinned all the wires which normally solder to the top of the OEM condenser, and I solder them all to a stripped end of the wire from the top of the condenser, I should have the same connection, Correct? :ugeek: Victor
Re: Condenser Connection
That is correct - and you won't have any worries about over heating the condenser.
It’s a bit of a tight area to solder in, but I guess no more so than soldering on top of the old style condenser & no chance of having solder hit the outside of the condenser. :ugeek: Victor
Make sure you route the wire so it doesn't contact the rotor.
Already done that. Thx. :ugeek: Victor
Check the timing and check for spark.
