Which Resonator Volume/Issue???
I looked at ever single TOC for every Resonator Issue & did not find the Clutch Blueprint article! Which volume/issue is it in, and what is it titled, because there’s nothing in any of the TOC’s I searched which says Blueprinting Your Clutch or anything similar! Thanks in advance! ,Victor
Re: Which Resonator Volume/Issue???
On the Club Site, mouse over and select the "How-To Resonator Index". You will see that it is in Volume 1 Issue 4.
Thank you Dale! I went straight to it now! And I was able to book mark it so I can go right back to that issue! Victor
Yes, I like it when a idea like the index works.
