Brake plate wearing on drum
I was riding today and noticed aluminum dust on my rear brake plate. Upon further inspection I could see if was rubbing against the drum. Any thoughts why?
1966 Norton N15CS
1975 Yamaha XS650 Brat Project
1975 Road Toad
1979 Yamaha XS650 Special
1990 HD Springer
1975 Road Toad
1990 HD Springer
Re: Brake plate wearing on drum
I just replaced the bearings and the seals last week. I should have mentioned that. I’ll be pulling the rear wheel off today to inspect it, but I’m 99% sure everything has been installed correctly.Bullfrog wrote:Bearing(s) worn out?
1966 Norton N15CS
1975 Road Toad
1990 HD Springer
1975 Road Toad
1990 HD Springer
hmmmm, OK . . . bent axle?
? forgot to reinstall the spacer tube between the hub bearings???
??? Wrong bearings? Sounds silly I know but, I once got a set of bearings for the front wheel from the local NAPA store. I gave him the bearing number (6201) . . . and he gave me some 6201 bearings EXCEPT these had a 1/2" center hole (not the metric sized hole I was after). The wheel was a bit floppy on the axle with those bearings (didja notice how far I got before I noticed the problem??)
I’ll check the axle when I pull the wheel. Spacer is installed. Hoping I got the correct bearings from Hodaka parts. I compared them before the reinstall. The seals went in almost too easy.
1966 Norton N15CS
1975 Road Toad
1990 HD Springer
1975 Road Toad
1990 HD Springer
I had this happen on a 1970 Hodaka. The Axle was bent. Your Model is so burly that the Rim will Taco first! Joe.
. . . and I hope this isn't it - check the "tower" which contains the bearing on the brake side for cracks.
I’m wondering if I got these two bearings reversed in the drum section. Or does it make a difference? Axle is straight.
1966 Norton N15CS
1975 Road Toad
1990 HD Springer
1975 Road Toad
1990 HD Springer
So I looked at the old bearings and lo and behold, there were two thin washers stuck to it. One on each side. Removed the new bearing and inserted the washers and it no longer rubs. Crises averted. Thanks for the guidance.
1966 Norton N15CS
1975 Road Toad
1990 HD Springer
1975 Road Toad
1990 HD Springer
Are the 2 seat rings (Part #929273) installed ? Joe.
You beat me to the Keyboard !!! Joe.
They are now!Joe Ormonde wrote:Are the 2 seat rings (Part #929273) installed ? Joe.
1966 Norton N15CS
1975 Road Toad
1990 HD Springer
1975 Road Toad
1990 HD Springer
Great stuff here guys. Excellent troubleshooting and problem solving. A good refresher/review of the Wombat wheel mounting department. Happy ending. Its all there. Thanks.
If you’ve still got the spacer out, it’s a good time to file 2 small u shape recesses on one end. It helps when next time you knock the bearings out as a drift will fit in the gap.
Bert
1968 Ace 100
94 & 94A Wombat
1968 Ace 100
94 & 94A Wombat
