Ace B Head Setting Washer
I know these are 7mm, but are they a specific type? Will lock washers work? Need to look for some locally, if someone can tell me if they are disc washers or lock washers or something different. Thx! Victor
Re: Ace B Head Setting Washer
Flat washer, slightly bigger than the diameter of the nut.
Thanks Thrown! Victor
Well I got my gaskets from Terry today. The Ace B+ went back together and the motor went on the frame before a late dinner this evening.
She’s wired back up, only left the flywheel cover off in case I need to check the points. Chain on, dropped the tank onto the frame but need to add the bolts.
Tomorrow, finish the tank, mount the seat, add the gear oil to the tranny and bolt on the carb, the carb slide & cable and attach the clutch cable. Then......
Ring-a-Ning-a-Ning-a-Ning!!!!! Victor
