03 shock bolts
Posted: Fri Apr 26, 2019 7:45 am
Help! I need to identify/locate bolts for stock 03 Wombat rear shocks. Attached are pix of correct (I think) top bolt (complete). I have the one set pictured, but need the other top bolt, as well as both lower bolts.
If you have correct bolts for an 03, could you measure and help me ID the needed parts? I have a pile of bolts, but dunno which is which.
Looking at Terry's schematic, I probably have the 929139 and the 949140 bolts which should fit the right side, but need measurements to ID them.
Also, 39139 & 39140 (left side) appear to be unique to the 03 model. Looks like I have the top one (pictured), need the bottom.
Finally, I have a mystery bolt also shown; anyone recognize it?
Might be easier to sort this out via phone. My number is 541-954-0101, if you have info and are willing to help!
