Wire Cover?
Posted: Tue Apr 23, 2019 12:54 pm
What are you folks using to cover the Blue & black coil wires coming out of the cases? The cover over mine has become hard and very brittle.
Are you just replacing it with heat shrink tubing? Is there something less susceptible to melting by the cylinder? Thx! :ugeek: Victor
Re: Wire Cover?
Posted: Tue Apr 23, 2019 2:26 pm
by Tether
If you disconnect the wires you can simply remove the old covers and install new that is available on line or maybe at better auto parts stores. I was successful using heat shrink tube just big enough to slip over the plug connector, 1/4” or 5/16”, the applied the heat. Worked well.
Re: Wire Cover?
Posted: Tue Apr 23, 2019 3:49 pm
by BrianZ
To maintain originality you will need PVC sleeving. Electronic companies like Digikey sell it. Most people use heat shrink as it is easier to find. Neither one is particularly heat resistant.
Re: Wire Cover?
Posted: Tue Apr 23, 2019 3:56 pm
Brian that is good to know. If you look at my photo, you can see the open portion closest to my hand. The wires & PVC cover were left between two of the head fins. I’m lucky it didn’t ruin the wires. I will see if I can find the PVC. If I can’t, I’ll just use heat shrink. I can always remove the bullet ends, run the wires through and terminate new bullets on the ends. :ugeek: Victor
Re: Wire Cover?
Posted: Tue Apr 23, 2019 4:11 pm
http://Www.Vintageconnections.com
They have the sleeving and connections needed.
Re: Wire Cover?
Posted: Tue Apr 23, 2019 6:00 pm
by gearyoliver
Dale,
Good find, that's a website to bookmark for sure!
Re: Wire Cover?
Posted: Wed Apr 24, 2019 12:57 am
by MTrat
If you fold one connector end back about 1/2" it makes the pair 'skinnier' to slide into the shrink tubing. Straighten it out afterward, before shrinking....
Re: Wire Cover?
Posted: Wed Apr 24, 2019 8:17 am
Dale. What diameter is the closest to OEM? Is it the 6mm or 9mm? :ugeek: Victor
Re: Wire Cover?
Posted: Wed Apr 24, 2019 10:07 am
viclioce wrote:Dale. What diameter is the closest to OEM? Is it the 6mm or 9mm? :ugeek: Victor
I use 6mm for 2-wire and 9mm for 5-wire.
Re: Wire Cover?
Posted: Wed Apr 24, 2019 2:42 pm
Thank you Dale! :ugeek: Victor
