So just got about 90% of my squirt disassembled and I got to the pivot bolt on swing arm and the thing is seized up to the swing arm. Will heat do the trick? Any one else run into this? Don't want to beat on it too bad and make it worse.
Shaun
01 pivot bolt siezed
Re: 01 pivot bolt siezed
Heat did the trick....
That was quick...
I'm very impatient!
