Seals 98 rat
Seals 98 rat
Hey guys, besides the crankshaft seal which protrudes a hair for the lube chamber, do the rest of the seals but right up to the bearing?
Re: Seals 98 rat
I set mine in flush with the case. I don't push them in till they touch the bearing.
Re: Seals 98 rat
Throwchain, is that personal preference or is that how they are typically installed. Are there any negatives to butting them up against the the bearing?
Re: Seals 98 rat
I'd say it's a personal preference, but been doing it that way for 40 years.
Re: Seals 98 rat
Ok, thanks for the advice.
Re: Seals 98 rat
With the already noted exception for the magneto side crankshaft seal, seals get pressed in to a point flush with the exterior of the case bosses.
There is nothing good which can come from pressing the seals in further than flush. (There may not be anything bad . . . but there is certainly nothing which is better by pressing in further.)
