Inner foot change cover
mac
Post by mac »
Is it necessary to use a silicone sealant in between the mag cover and inner foot change cover and then for sealing the whole assembly to the cases ?
Re: Inner foot change cover
There is a foam seal on the rear mating surface between the outer and inner. Other than that it is a dry fit. If it's totally sealed, any moisture that may form inside the cover stays there, not good.
mac
Post by mac »
Okay,thank you!
