What You Think Maxie?
Posted: Tue Mar 19, 2019 2:45 pm
Pulled her apart & cleaned her all up. Pilot cleaned & re-installed, added a 90 main jet (smallest I had), and cleaned the slide & needle and lubed with 2R. Even provided the rubber cap & cable adjuster.
The floats look like shiny & new, the seat & needle cleaned up and even had a new bowl gasket for her.
The only thing I didn’t have was the correct sized air screw. Anyone want to make an air screw donation, for this VM20, before I send it to Alan?
Re: What You Think Maxie?
Posted: Wed Mar 20, 2019 1:51 am
Good job Victor! That carb probably wouldn't have seen the light of day again. I've looked everywhere for that air screw and it may be here yet. Glad to be a small part of the project! Maxie
Posted: Wed Mar 20, 2019 2:52 am
by Bruce Young
Victor, call me I have a pile of VM 20 parts and pieces, If I don,t have it I am sure we can suggest in your own town at a local m/c shop where you can get that air screw, Bruce Young you have the number
Posted: Wed Mar 20, 2019 11:41 am
by dirty_rat
They normally came with a 95 main jet, stock. They usually came with a 90 and 100 as extras.
Posted: Wed Mar 20, 2019 1:41 pm
According to my Ace 90 manual, the VM20 for an Ace 90 came with an 85 main in place and an extra 80 & 90 main as well. This isn’t for an Ace 100.
Posted: Wed Mar 20, 2019 1:43 pm
Bruce. Called Wednesday evening around 6:40. Left a message....
Posted: Fri Mar 22, 2019 6:06 pm
by dirty_rat
Are you going to put that carb on an Ace 90? If so, the 90 main jet will probably be okay. If you are going to use it on a 100, best to start out with a 95 or 100 main jet and tune from there. The Ace 100's came with a 95 main jet from the factory.
Posted: Sat Mar 23, 2019 5:54 am
As I stated, it’s going on an Ace 90.
