There was a lightning kit made for the dirt Squirt, part No. 923013. Does anyone know if this will work for the DS 80. I have not checked yet to see if the 80 has a lighting coil but the parts diagram indicates there is.
Thanks,
Dirt Squirt 80 Lighting kit
Re: Dirt Squirt 80 Lighting kit
Since the bottom end is basically a Toad motor, then I would imagine that Toad lighting will work.
The pat number you are quoting is an Ace 100 lighting coil, which is the same as the chrome tank Dirt Squirt lighting coil. This part will not fit your DS80. Your DS80 should have a lighting coil, and as Dan has already stated, should be the same as the Road Toad. The Dirt Squirt lighting could be made to fit but all you would be using would be the headlight. You could look for a Toad headlight but I am not sure if the spacing between your fork tubes is the same. This goes for the Dirt Squirt lighting kit as well.
Brian,
You are correct, I looked at the box wrong. The box says you may need to buy a lighting coil with that part number.
I figured I would need to do fabracobble somthing up to mount the headlight.
I just think it would be fun to have lights on the little Squirt.
