Page 1 of 3
part number id wins
Posted: Fri Nov 09, 2018 5:35 pm
This first or closest winner will win a new set of hodaka points.
What was a 929510D? ---------Clarence
Re: part number id wins
Posted: Sat Nov 10, 2018 1:11 am
by thrownchain
92 B owners manual with parts list.
Posted: Sun Nov 11, 2018 1:30 am
by thrownchain
Am I the only one playing this time?
Posted: Mon Nov 12, 2018 5:27 am
Your close, keep going. winners are winners. --------------Clarence
Posted: Mon Nov 12, 2018 12:30 pm
by thrownchain
92 B workshop manual with parts list.
Posted: Mon Nov 12, 2018 12:39 pm
Almost , Clarence
Posted: Mon Nov 12, 2018 1:28 pm
by thrownchain
92 B+ shop manual with parts list.
Posted: Mon Nov 12, 2018 2:43 pm
You win! So far you have the points and a condenser, keep it up and you might end up with a complete? ----------Clarence
Posted: Tue Nov 13, 2018 5:08 am
by thrownchain
Most likely a tune up kit.
Posted: Fri Nov 16, 2018 1:42 am
win a 904611, 904013, 901408.
Curt Alexander. where did he work and what did he do? ---------------Clarence
Posted: Fri Nov 16, 2018 6:40 am
OH, OH! I know, I know.
I raised my hand - pick me. I know this one!
Posted: Fri Nov 16, 2018 8:07 am
Just like my pillow, "I know you would" ----------------Clarence
Posted: Fri Nov 16, 2018 4:36 pm
by thrownchain
Not sure about before Pabatco, but was in R+D with Harry. Helped upgrade many of the early issues.
Posted: Fri Nov 16, 2018 6:57 pm
1/2 what was his trade? Clarence and if I am wrong Ed can judge ------------Clarence
Posted: Sat Nov 17, 2018 1:27 am
by thrownchain
Machinist, fabricater, tool and die maker.
Posted: Sat Nov 17, 2018 11:49 pm
Throwchain you win again more to come. --------------Clarence
Posted: Sat Nov 17, 2018 11:52 pm
Throwchain you win again more to come. Does anyone have anything Curt made? --------------Clarence
Posted: Sun Nov 18, 2018 2:01 am
by thrownchain
like the old Johnny Cash song, "one piece at a time".....
Posted: Sun Nov 18, 2018 6:59 am
Well its a 65,66,67,68,69 70,71,72,73,74,75 Ho-da-ka...hard to sing.
Posted: Sun Nov 18, 2018 10:55 am
Clarence, Curt made beauteous weighted clutch on my trials machine. I'll try to find some photos.
Posted: Tue Nov 20, 2018 7:01 am
Whew! I had to search files all the way back to 2005 when I was bringing the Bullfrog trials machine out of its 27 year retirement in the dark and stacked over regions of the garage. Curt Alexander machined the custom, heavy outer clutch cover for some of the Bullfrogs (I'm not sure how many.) I think the piece is a beauty!
- Heavy clutch outer cover with note
The note suggests that anyone taking on the task of machining a clutch cover like this should consider not taking the time to create the raised ridge/lip near the center of the item. This raised lip requires 1) a larger piece of parent stock to make the part, 2) more material removal while machining, and 3) provides extremely minimal additional rotational moment of inertia. In short, it takes more material/work to create it than the benefits it provides.
- Heavy custom trials clutch cover
This photo shows the weighted clutch installed on the crank.
- Inside of heavy clutch cover
This photo shows internal details of the custom heavy outer clutch cover.
NOTE: If anyone wants to machine up one of these items, I have a detailed, dimensioned drawing created by measuring the item in the photos which can be shared.
PS: Curt did NICE work!!!
Posted: Tue Nov 20, 2018 8:29 am
by thrownchain
Must be a tight fit under the cover. Does this modification work? It would seem that with the clutch basket rotating slower that the flywheel that benefits would be less? Or do both spin at similar speeds?
Posted: Tue Nov 20, 2018 9:03 am
Yes, it works. It ran on my Bullfrog from 1971 to 1978, took a 27 year vacation, then started being used again in 2004 to the present. I think there may have been a failure in the mind picture imagining required to visualize where this item is in the power train. Take a look at the Illustrated Parts List for the Wombat. If I were going to give this part a part number, it would be 934008isoCAH (clutch cover - Curt Alexander Heavy). It gets substituted in for PN 934008iso and always spins at the same speed as the clutch hub (944012) which mounts to the crankshaft splines.
Posted: Tue Nov 20, 2018 10:18 am
by thrownchain
Doh, that's right, clutch and flywheel are both on the crank, just on opposite ends.
Posted: Tue Nov 20, 2018 11:05 am
throwchain what part would you like to win? // or I will pick another. In the mean time, win a 125cc combat piston ring just the ring. How many hodakas were made the first year? -----------Clarence------- And I will find a piece made by Curt.
