Engine build question.
Posted: Mon Nov 05, 2018 4:44 am
by Larry S
Will a iron barrel Wombat top end bolt to a Ace 100B bottom end?
Larry S
Re: Engine build question.
Posted: Mon Nov 05, 2018 7:03 am
I believe the answer is no, because the bolt pattern for the Wombat is wider apart than for the Ace.
There was a 125 upgrade made for the Ace, by Webco, I believe, but those have become very hard to find these days. ; D Victor
Posted: Mon Nov 05, 2018 11:45 am
Victor is right. Different stud pattern plus 8mm studs on 125 vs 6mm on Ace engines. Different cylinder spigot diameters too.
Posted: Mon Nov 05, 2018 12:47 pm
by Larry S
Thanx Victor and Captain Eddie.I don't know if you saved me some money,or cost me some money.Now I need to find a iron barrel Wombat engine.
Larry S
Posted: Mon Nov 05, 2018 1:14 pm
Check with Bruce Young at hodakaoarts.com. You can also find him on “the Hodaka Club” On Facebook! ; D Victor
Posted: Mon Nov 05, 2018 1:23 pm
Is your goal to just build a 125? Or is your goal to build a motor which will fit in an Ace frame?
There are more options of which you may not be aware. How about disclosing to us a little more about what you are thinking? :ugeek: Victor
Posted: Mon Nov 05, 2018 4:41 pm
by thrownchain
I have an iron barrel wombat motor. May need a new cylinder, or may be boreable, need to check with my boring guy. Rest of the motor is in decent shape.
Posted: Mon Nov 05, 2018 5:23 pm
by Larry S
My daily rider is a Ace 100B.I' m a little fart 125 lb. I want to be able to cruse at 55. I can do that now,but the engine is working hard. I am going to build a bad ass engine that looks stock. I want to be able to cruse at 55-60 without overworking the engine.I think I can do this on my own,but if it is over my head Ron Leddle can build it for me.
Larry S
Posted: Mon Nov 05, 2018 5:39 pm
by Larry S
If the engine is on the first or second overbore i'm interested.
Larry S
Posted: Tue Nov 06, 2018 8:22 am
by rlkarren
Dropping a 125cc engine into an Ace frame is loads of fun. This bike easily hits 60 Mph cruising speed. If only I had another Circle F... :|
