94 Wombat clutch spring length ?
Posted: Thu Oct 04, 2018 3:53 pm
by Tether
I’m working on a Wombat 94 engine H03940. Took the clutch apart to check everything. Everything looks very good and measured well within specs except the springs.
Outer springs all measure closely the same at .66” the manual says this should be .79” that seems kike a huge difference. Is possible for these to collapse this much? Do I have the wrong springs? Misprint in the Manual?
The inner springs measure at .67” which what the manual says they should be.
Re: 94 Wombat clutch spring length ?
Posted: Fri Oct 05, 2018 12:31 am
by thrownchain
Yes the springs will collapse over time.
Posted: Fri Oct 05, 2018 2:57 am
by Tether
Ok thanks.
I assume then that these should be replaced.
Any advice on where I can get these. I have looked around and can’t find any.
Posted: Fri Oct 05, 2018 3:36 am
by Bruce Young
Tether;; the newest and largest collection of Hodaka Parts ever, and at reasonable price,s is the all new business; Hodaka-parts INC Terry Larson, Union, Missouri, 1--314--313--5635
Posted: Fri Oct 05, 2018 3:45 am
by Tether
Terry,
I checked your store and there was nothing listed under the model 94 but I did find them listed under model 92 with the same part number. I ordered them. Is this correct?
Posted: Fri Oct 05, 2018 4:06 am
by thrownchain
Same part number same part.
Posted: Fri Oct 05, 2018 5:14 am
by Bruce Young
Tether, if you order #934011 those fit lots and lots of diff models including 94 and 92,s same on the inner number #934017 there is a compatible parts chart on his site as well to help with what fits what. . Bruce
Posted: Fri Oct 05, 2018 5:25 am
by Tether
Thank you Bruce,
Yes that is the part I ordered.
