Hodaka Racks fit???????
motovate
Post by motovate »
So the question is - Will any Hodaka rack fit the frame of an 01 Dirt Squirt - which I understand is basically a Wombat Frame - or do I need a wombat or road toad rack???? :?:
Thanks LBM
Re: Hodaka Racks fit???????
This is not a definitive answer, but I don't think the earlier ACE era racks will fit on a painted tank Dirt Squirt. Likewise, I have my doubts about the rack for a toaster tank Wombat. But I'm sure that at Road Toad rack will fit the Model 01 Dirt Squirt.
motovate
Post by motovate »
Thanks. Any Idea what the difference is between the rear of Toaster Tank Wombat Frames and the painted tank Squirt frame? Maybe the 01 frames were a "later??" Wombat frame? Or was it a matter of the process of design starting with the Wombat Frame and redesigning to fit the 01/02 concept???? Just curious.
LBM
rlkarren
Post by rlkarren »
Mounting tabs are slightly different. You’ll need the Road Toad (02) rack, if memory serves.
motovate
Post by motovate »
Thanks The Toad it is. I was hoping the wombat was close enough to maybe elongate or redrill some of the holes to fit rather then cut & weld.
LBM
