Onward with the Green Model 99 Road Toad
Was looking at the rear brake today. It seems the rear brake rod is missing the forward tab for the rear brake light spring to attach! The Red Toad is gone so I don’t have a reference. I can make the tab with the whole in it and weld it on, but I need to know the distance between the rear return spring tab and the front brake switch spring tab. Can someone with a Model 99 give me the distance? Either from the end where the rod connects to the brake pedal, or the distance between the two tabs with holes on the brake rod? Thanks! :ugeek: Victor
