Front fork leak.
Front fork leak.
Hello all, I have developed an oil leak at the bottom of thefront fork on my ace 100. I believe it’s the drain screw. Has any one had this issue? If so it there a good replacement seal/ packing anyone would recommend. Thanks Dean
Re: Front fork leak.
You should be able to order them from the Hodaka Parts suppliers. If they don't have them they are the same as the early model Suzuki's.
Check with Terry Larsen at http://www.hodaka-parts.com, because he has bought out both Dan and has also bought out StrictlyHodaka.com. It’s become a one stop shopping experience for Hodaka needs! Looks like it’s just Terry, Bruce & Hodaka Dave are the only ones left, and all are offering rebuild work, I believe, except for Bruce? Not sure if Bruce is offering service work or just used parts. Victor
