250ED seals
Hosk1956
250ED seals
Post by Hosk1956 »
I am looking for a bit of help, I have finally got to re assemble my 250ED motor. I had sourced all new engine oil seals locally (postage and the sagging dollar will break my budget, a $US10 seal ends up being $40+ in Australia), but I can't find the RH or clutch side crankshaft oil seal (pt # 711003), worst part is I can't find the old one to get a size of it! Can someone measure a 711003 seal for me, it looks like the pinion gear collar (712717) goes thru this seal, which by measuring will make it 42mm OD x 32mm ID x 8mm thick, but I would like some confirmation.
At the end of the day I may have to bite the bullet and import one, but if I don't have to it is dollars to go elsewhere on my Hody project.
Wayne from Oz
racerclam
Re: 250ED seals
Post by racerclam »
here are the seal sizes for the 250 , sorry I dont have the location for you but you should be able to figure which one you dont have
25x42x8
32x42x7
32x52x8
16x24x4 kick shaft
Hosk1956
Re: 250ED seals
Post by Hosk1956 »
Thanks Rich,
I got the correct seal, phew.
It all came back to me but when I got all the seals locally they didn't have that one in stock, it wasn't listed as an item. I had planned to buy that one in but much time has elapsed (too much time) and I had forgotten to order it, fortunately, my local bloke was able to get one in, he couldn't understand why I couldn't get it the first time.
All good now, bottom end is together, now for the top end, and file the chatter marks out of the clutch cage fingers.
Wayne from Oz
racerclam
Re: 250ED seals
Post by racerclam »
glad to help
