motors f/s
motors f/s
I will have a couple of motors to sell at HD, one is a "P" series Ace and the other a "E" motor. Both overhauled. The "E" has new crank and piston as well as the clutch. Good clean cases. The "P" has a new piston on a good crank. Both have new bearings, seals etc. Bring cash.
djdesantis
Re: motors f/s
Post by djdesantis »
What are you looking to get for them?
Re: motors f/s
I'd like to see a grand for the Ace motor, and maybe 1250 for the "E" motor. I don't have a good shift cover for the "E" so I can be a little flexible on that. I am open to cash offers.
Re: motors f/s
I still have the "E" motor. Can haul to Mid Ohio if anyone is interested. Will have an overhauled shifter by then.
Re: motors f/s
Currently building another Ace 100 motor if anyone is in the market. The deal I struck at HD was his core motor and some cash, worked out as the core wasn't in bad shape. Broken kickstart roller cage, and scarred shaft, both of which I have good replacements. In the reassembly stage, should be done fairly soon.
