VIN vs Frame #
VIN vs Frame #
They are the same, correct? The VIN # & the frame # are identical, aren’t they? :ugeek: Victor
TheBevman
Re: VIN vs Frame #
Post by TheBevman »
Yep, unless the vehicle has had a different vin# assigned. Some states will do that if there is no documentation and someone is trying to reg it, but they'll usually pull off all other tags or identification. I just reg'd my "Odd 90" and they took the frame #as the Vin and in CA they want the engine # too just to make sure you don't swap it for a "gross polluting" engine. There's an idea a Hodaka with a diesel engine.
Bev
'72 Wombat (94)
'65 ACE 90? (Frame)
'66 Triumph Bonneville
'99 Triumph Adventurer
'66 Ace 90/100- Dirt only
Re: VIN vs Frame #
Thanks! VIN inspection complete! Onward to MVD!!! ; D Victor
Re: VIN vs Frame #
The frame and engine numbers are not the same. Not once have ever seen. --------Clarence
Re: VIN vs Frame #
Well that’s understood but not the question! ;)
Re: VIN vs Frame #
It is so well understood I did not realize it could be a question. It was my cell phones fault. No for my age I screwed up. Now we move on to something important.-----Clarence
