Crankcase oil ?
Posted: Fri Apr 27, 2018 6:10 am
by Dean Simms
Hi all, I picked up some Bel ray gear saver 80wt oil that is recommended in the forum. I noticed there is also a Bel ray gear saver 80wt-90wt gear oil type for sale in strictly hodaka.Hoping I'm using the right oil.Thanks Dean
Re: Crankcase oil ?
Posted: Fri Apr 27, 2018 6:31 am
by socalhodaka
Yes your good.
Re: Crankcase oil ?
Posted: Fri Apr 27, 2018 6:41 am
by ossa95d
Double check to make sure that you got the Gear Saver Transmission Oil and not the Gear Saver Hypoid Gear Oil. The bottles look the same but Hypoid Gear Oil is NOT recommended for wet clutches. Odds are if it is straight 80w it's the correct oil.
Re: Crankcase oil ?
Posted: Fri Apr 27, 2018 8:15 am
by Dean Simms
Looks like I got it right thanks for the response
Re: Crankcase oil ?
Posted: Fri Apr 27, 2018 11:47 am
by socalhodaka
Case close everyone
