Swingarm bushing R&R
Posted: Wed Oct 30, 2013 3:51 pm
by TommyJ
Gentleguys,
I'm prepping the frame of my Ace 100 for powder coating and am puzzled by the chromed steel bushings in the swingarm. The Clymer manual exploded view shows the swingarm with the bushings in place- as one component. That doesn't seem right. Should the bushings be removed with a long drift? Or should they be left in situ and masked off during beadblasting and powder coating? Thanks for the help!
TommyJ
Re: Swingarm bushing R&R
Posted: Wed Oct 30, 2013 4:28 pm
by BrianZ
Just to clarify, these "bushings" are not really bushings in the traditional sense, but rather spacers. Once the swingarm axle is tightened these spacers are drawn up tight against the rubber bushings in the frame, and the rubber bushings flex to allow the swingarm to move. Now, getting back to your question, in the past I have removed the spacers to have them replated (they are zinc plated) and then reinstalled them in the newly powder coated swingarm. In my opinion this is the "correct" restoration method. You can also mask them or paint them depending on how authentic you want the bike to look. If I remember correctly, they can be a bugger to get out!
Posted: Thu Oct 31, 2013 12:59 am
by thrownchain
One thing you may want to find out, are replacements available if I destroy these getting them out?
Posted: Thu Oct 31, 2013 3:25 am
by socalhodaka
I would just tape them off.
Posted: Thu Oct 31, 2013 4:48 am
If the outer faces of those "bushings" are not worn, I'd recommend leaving them in place and masking them off.
This particular bushing is not a "wear" part. It press fits into the swing arm . . . and then when the swing arm bolt is tightened, the complete swing arm assembly (including these bushings) is clamped tight against the inner sleeve of the bushing which is pressed into the frame. The inner sleeve in the frame bushing is allowed to rotate a bit by the surrounding rubber. In this way, ALL part-to-part movement is eliminated - hence, no wear. (all movement is focused in the rubber part of the frame bushing).
However, IF, the swing arm bolt happened to be loose for a considerable stretch of riding, then the face of swing arm bushings could have been "dished out" -- which means they should be replaced. I don't think those are available as spare parts - but they are easily manufactured out of mild steel on a lathe.
Posted: Thu Oct 31, 2013 5:53 am
by admin
Yes Ed you are correct these "end caps" to the swingarm are not a stock Hodaka part. They were never offered as a replacement part.
Thank you
Posted: Wed Nov 06, 2013 7:10 pm
by TommyJ
Thanks, guys! In they stay.
TommyJ
