Best Tank Rust Cleaners
Posted: Sun Jan 21, 2018 11:04 am
Have a friend with a really badly rusted tank. Not enough to leak but bad enough to need cleaning.
I’ve read on this topic here before, but I only got 4 posts on my search. So what treatments do Hodaka folks like for rusty tanks? Shake & rattle with something inside the tank? A chemical rust remover? Need some good starting points. This is a no premix tank we are talking about. Thanks!
Re: Best Tank Rust Cleaners
Posted: Sun Jan 21, 2018 12:27 pm
Hi Victor, I really like and frequently use Evaporust. I know a lot of people swear by elecctrolytic derusting, but having tried it, it works no better than Evaporust and does require a bit of fiddling around. Don't be surprised if pinhole leaks develop after the derusting process. If that occurs, Caswell 2-part epoxy tank sealer is an excellent fix. I've resurrected several tanks with this combination with great results and durability.
Posted: Sun Jan 21, 2018 2:22 pm
by DG29
It may have been here, but I'd seen apple cider viniger mentioned to remove rust inside of gas tanks. I gave it a try along with some loose bolts and nuts and the stuff worked out pretty well. Your friend might want to give it a try.
Posted: Sun Jan 21, 2018 3:05 pm
by squid on a 300
clean out all the old gas and varnish with carb cleaner..use the screws/nut/bolt procedure to get ride of the big rust flakes...then soak with Evaporust..if it's cold put the tank under a heat lamp...if nice and sunny and warm out set it outside in the sun....the product works best above 75 degrees F...I tried Metal Rescue once...Went right back to Evaporust...
Posted: Sun Jan 21, 2018 5:38 pm
As the squid said, cleaning out the old gas oil sludge and varnish is a must. I use Lacquer thinner for that with the nuts screws ect with the shaking. --------------Clarence
