I need a set of springs from the 34mm forks, any model is fine.
Kelly
Im Looking for some fork springs
Re: Im Looking for some fork springs
Hey Kelly, Have you tried Bruce Young? He always seems to have everything at a good price! 208-571-2823
+ 1 on Bruce! He usually has things like this and will always send you the best pair he has! Victor
If no luck there, most of the springs from mid to late 1970's Japanese bikes with 34 mm forks will probably fit. You can also get different spring rates depending on what model bike you get the springs from (the heavier big bore bikes will have stiffer springs).
