toad pump
toad pump
As you look at the pump, which oil line goes on which side? Input on left or right? Thx
Re: toad pump
According to a photo on a Dealer set-up sheet for the Road Toad model 02, the intake banjo bolt is on the right and the output to the engine is on the left.
Re: toad pump
Thx, that's what I thought, but it is opposite of what you would think as the tank is on the left and you would think the pipe would go to the closest port, but it crosses over the pump to the off side. Always fun ( I should have snapped a pic when I took it apart).
