Special tools
Posted: Wed Sep 13, 2017 3:03 pm
by SScratch
I am replacing the shift control shaft springs on my Ace 100B+. Although I was able to get everything disassembled without any special tools, getting it all back together is another story. Any way to reassemble without spending another $100 on special tools? Anyone near Nashville want to help a brother out with a clutch holding tool and snap ring tool?
Re: Special tools
Posted: Wed Sep 13, 2017 5:36 pm
by racerclam
I assembled for years before I had the tool . Its do able I used vise grip needle nose pliers to hold the clip retainer down compressing the springs then spread the clip a bit and work it over the shaft with regular needle nose pliers and one its over squeeze it then release the retainer . Its pretty easy. But don't squeeze the retainer out of round with the needle nose.
Re: Special tools
Posted: Wed Sep 13, 2017 6:08 pm
by Hydraulic Jack
46 years later and I still don't have a special tool for the shift shaft spring clip. Didn't know there was one until last year.
Re: Special tools
Posted: Thu Sep 14, 2017 12:19 am
by Bill2001
The clutch-holding tool is multi-purpose. Not only does it hold the clutch, it also holds the primary gear, the flywheel/ alternator rotor and the output sprocket.
Re: Special tools
Posted: Mon Sep 18, 2017 10:58 am
by SScratch
Is it possible to buy a couple dozen of these snap rings locally or are they something special? I cannot seem to find any.
Re: Special tools
Posted: Mon Sep 18, 2017 11:47 am
by Alberta Mike
In my experience, after market snap rings (like the plastic box full you might pick up at Harbor Freight, etc) are essentially junk and are nowhere near the quality of OEM snap rings (or any other fasteners, etc). And the thickness can also be an issue even if the diameter might seem correct. OEM fasteners of this type can usually be reused, but usually not so with the crappy ones or if they get a little bend in them, etc.
Re: Special tools
Posted: Mon Sep 18, 2017 11:58 am
The control shaft snap ring is a proprietary part. I don't think you'll find a suitable replacement anywhere other than the known Hodaka parts suppliers.
Re: Special tools
Posted: Mon Sep 18, 2017 12:35 pm
by SScratch
Well that is disappointing.
Re: Special tools
Posted: Mon Sep 18, 2017 12:59 pm
. . . on the other hand . . . you can STILL get that itsy-bitsy and critical part. I think that is kind of neat.
Re: Special tools
Posted: Mon Sep 18, 2017 2:08 pm
And I would add that after improvising and failing miserably with cut off drifts, needle nose pliers, and profanity, the snap ring tool is a must have. The 2,000 snap rings laying about all over my shop floor attests to how slick the thing works. I'd be interested in knowing how to predictably place the snap ring on the control shaft without it. Mine stays safely tucked away in that little skinny drawer at the top of my tool chest, but it would be nice to know the alternative technique. One never knows.
Re: Special tools
Posted: Mon Sep 18, 2017 2:19 pm
by Thunderdogdownunder
Just use a big flat washer with a hole slightly bigger than shaft .. place over top of shaft then press down compressing spring . My friend gave me the tip a few years ago .
Re: Special tools
Posted: Mon Sep 18, 2017 2:28 pm
Hmm...that's a sad indictment if my mechanical ingenuity. That never occurred to me. I do like the way the snap ring radially and symmetrically expands over the thick end of the taper before it drops off onto the control shaft but in a pinch, the maneuver you describe would turn the trick. I have an Ace 100 motor that I use for technical practice. I'll give that a try. Thanks for the tip.
Re: Special tools
Posted: Mon Sep 18, 2017 4:29 pm
Doesn't Paul offer the snap ring tools? I remember Danny making some for him. If Paul is sold out, is there another resource for them? Does Danny ever make them on request? Just done thoughts here..... Victor
Re: Special tools
Posted: Tue Sep 19, 2017 3:46 am
by rlkarren
Stop by your local hardware store and browse through their selection of springs. Once you find a spring that is the same wire diameter and spring circumference, clip and discard the ends and start clipping rings off... insta-snap-ring.
You could probably cut the spring lengthwise with a dremel. That might be the easiest method. Either way you'll have an abundance of snap rings made of spring steel.
$0.02
P.S. It probably doesn't matter whether it is a compression or extension spring, but the extension spring will give you more clips.
Re: Special tools
Posted: Tue Sep 19, 2017 5:03 am
by Bill2001
Good thinking on the home-rolled spring clips.
Bosch starters use the a similar clip/retainer on their Bendix shafts. 10mm dia, much heavier and a bear to install. I made a similar tool to the Hodie tool, and I bought the Hodie tool early on.
It's helpful but not essential, but at least I supported our local cottage industry.
Re: Special tools
Posted: Tue Sep 19, 2017 11:17 am
Why. reinvent the wheel when the correct part is available? They cost very little.--------Clarence
Re: Special tools
Posted: Tue Sep 19, 2017 12:37 pm
by Bill2001
But if it's Sat afternoon and you just sproinged your last circlip circlip trying to install it, you don't want to wait a week to order a factory part when the equivalent can be easily made.
Re: Special tools
Posted: Tue Sep 19, 2017 1:26 pm
I think it was a motto be prepared. ----Clarence
Re: Special tools
Posted: Wed Sep 20, 2017 8:48 am
by rlkarren
taber hodaka wrote:Why. reinvent the wheel when the correct part is available? They cost very little.--------Clarence
Because, if that's the only part you need, it's almost a $10 part when you figure in shipping. Not to mention the time it takes to arrive.
I'm not complaining, just pointing out the reality of the situation. There are some cases where having
the correct part is not important. Other times it is critical. I think a snap ring is one of the former, as long as it is functional.
$0.02
