I pulled this off a 100 motor I have and am wondering if it is a stock replacement or part of something else. The inlet (carb side) measures 26mm diameter which seems big for a 100. Maybe it's not a Webco?
John Hjelm
Webco intake mainifold
Re: Webco intake mainifold
That is indeed a Webco manifold for mounting larger carbs on Ace 90/100s. Our racer had already jumped to a homemade manifold with 32mm Amal carb when these came out. Model 93 Super Rats came out with a similar manifold but with a four bolt pattern on the cylinder. The reed induction was also soon to come out leaving the piston port manifold somewhat obsolete or at least a low sell item. Cool, kinda rare!
Hi John,
Would you consider selling the intake? I'm updating a 72' Ace? It had a a Webco sticker and I have 3-4 Webco accesories so far. Thx Dan 310.975.4732
