Carb Top Cap Gasket
Posted: Wed Jun 28, 2017 6:17 am
by go_hercules
My Dirt Squirt carb top that screws on the top of the carb (called the mixing chamber cap in the parts list) has no gasket. There is not one shown on the parts list. But I thought there was supposed to be one there. Does anyone know for sure. By the way, looking at a parts list for a modern VM20 carb, they show a gasket there. Thanks.
Re: Carb Top Cap Gasket
Posted: Wed Jun 28, 2017 6:56 am
by racerclam
You can buy that gasket separate. They come with the cap if you can find one
Posted: Wed Jun 28, 2017 6:57 am
by racerclam
I mean cant !
Posted: Wed Jun 28, 2017 7:55 am
by go_hercules
The Dirt Squirt cab has the top cap that is like a ring that fits over a disc shaped top piece. So if it had a gasket I would have thought it would show as a separate piece. Just want to know for sure.
Posted: Wed Jun 28, 2017 8:41 am
I don't remember a gasket at that location on the toaster tank squirt carb. But that is a far from definitive sort of comment, since it has been almost 40 years since I've worked on a stock toaster tank squirt carb.
Posted: Wed Jun 28, 2017 8:55 am
by Bill2001
Take look at the parts book drawing at Simply Hodaka. If one was used it will be shown.
Posted: Wed Jun 28, 2017 9:06 am
Looking at the Illustrated Parts Lists is in the 99.9% percent sure way to go . . . but, I know the parts lists don't show the seal retainer snap rings in the fork sliders for the 03 Wombat. go-Hercules is looking for confirmation from Squirt owners that no gasket is indeed correct I think.
Posted: Wed Jun 28, 2017 10:51 am
by go_hercules
Right Ed, just trying to make sure. The parts list doesn't show one so I guess it probably did not have one.
Posted: Wed Jun 28, 2017 1:17 pm
Confirmation. Three out of three toaster tank Dirt Squirts prefer NO GASKET in the mixing chamber cap. On the Squirt carb as opposed to other Mikuni mixing chamber caps, the Squirt's is a two-part affair with a "lid" that is held down with a ring that threads onto the mixing chamber. This configuration is necessary for allowing removal of the slide for needle clip adjustments without twisting the throttle cable (which enters the cap off-axis on the Squirt carb as opposed to the central placement of the throttle cable on the one piece Mikuni mixing chamber caps).
Posted: Wed Jun 28, 2017 2:56 pm
by go_hercules
Thanks very much for checking that out. I really appreciate it. You actually own three Dirt Squirts? Sounds like quite a fleet !!!!!
Posted: Thu Jun 29, 2017 7:38 am
Do you have the rubber top cap or do you need one. I have a few in my carb parts tackle box. If you have a VM20 carb & need one I can likely mail one to you but would have to look to confirm. Just let me know! :mrgreen: Victor
Posted: Thu Jun 29, 2017 10:35 am
Actually, I just scored a 4th Squirt. I needed four to hold up the corners of the tarp my wife is making me live under out in the back yard :-). Short money and a good start for a rider. $400 and came with a spare fresh first overbore cylinder and piston. I couldn't refuse. I'm thinking about turning it into a sleeper.
Posted: Thu Jun 29, 2017 11:00 am
by go_hercules
Hi Victor. My rubber top cap is in place so I am good there. Thanks for the offer.
Matt, my wife said "either the bikes go or I go". I sure am going to miss her.
Posted: Thu Jun 29, 2017 11:58 am
HaHa! I'm marching down the same road, Go.
Posted: Thu Jun 29, 2017 5:49 pm
OK! Glad you're getting it worked out!
Matt. If you want you can live in my garage with my 4 Hodaka, 2 Suzukis & the mini KTM! Bring your 4 and we'll just need one more for an even dozen...unless I get that Thunderdog! :mrgreen: Victor
Posted: Thu Jun 29, 2017 8:16 pm
Sounds good to me Victor. We'll have plenty of bikes to wrench on!
Posted: Fri Jun 30, 2017 2:46 am
by go_hercules
Hey guys, I had a question about an old Honda Elsinore that I have. Not a Hodaka but you guys could probably help me with it. When I set the air screw for the highest idle, the engine hesitates when I blip the throttle. So I can turn the air screw in to richen it up and get rid of the hesitation. But I end up going from about 1 1/2 turns out (highest idle) to about 1/2 turn out (best response). Why in the world are these two adjustments so far off. I thought setting for the highest idle should get you very close on the air screw adjustment. I don't get it.
