Model ID help- Super Rat, Ace100?
Posted: Fri Sep 20, 2013 8:55 am
Hi-
I have begun rebuilding my Dad's old Super Rat that's been collecting dust in the shed for the last few decades, and was hoping someone might have some insight onto which combination frame/motor this actually is. The frame is A-50794, and the motor reads F1034. Also I don't know what it means but there's another number stamped 921001-01 on the motor for whatever its worth. He thought it was just a 93a model super rat, but the wiring doesn't match the diagram for that bike. According to the diagram the super rat motor should be wired to have a kill switch, but this has four wires coming out of the ignition that look like the diagram for the Ace 100, with the coil and ignition wire setup. The box of parts has no kill switch or ignition switch, so I'm trying to figure out if I can wire up a switch or cross some wires (without frying something) to get the ol' girl running again. Any advice/insight would be greatly appreciated, I'm very excited to get this project going, I'm hoping to surprise the old man with a clean running bike for Hodaka days next year!
Also- someone installed a reed valve and appropriate piston in this motor as well, if that helps in the ID
Rob
Rob
