32 mm carb
32 mm carb
anyone running a 32mm carb on a piston port (CW non reeded) motor? If so how did you go to spigot mount. Any one running a flat slide carb? thanks
Re: 32 mm carb
I recently did that conversion for Henry Gregorich . I used a rubber mount from sudco and a 34mm round slide with aUFO and 6 venture dividers . Also opened up the intake manifold to match the carb. You don't want flat slide , a round slide will out perform one with a ufo up to 13/16 throttle opening and is almost equal at wot. You can check out Henrys testimonial on my web site richstaylordporting.com .
