68 ACE shift problem
Stalled on my b+ problem. Only because it's time to spend money. My 68 has been tough to get into neutral and also sometimes when I shift into 1st it wants to go gack gack between 1st and 2nd like it can't find them. Once I'm in 1st it's fine. Do you you think this is a shifter alignment problem or something internal. I was going to try and align it, but I hadn't posted in awhile so I'd thought I'd ask. Hope y'all doing well.
Re: 68 ACE shift problem
viewtopic.php?f=1&t=2503
I asked a similar question a few weeks back and received lots of great advice. If you read the entire thread you'll see the problem through to it's conclusion. (yes, it involves spending $)
Click the link above and it should take you to the thread.
good luck with it.
Ken
good luck with it.
Ken
I wonder where this goes...?
