Replacing swingarm bushings
- rough rider
This is one of the few frames that I have ever needed to replace the swing arm bushings on. I wasn't sure what would be the best way to remove and install them on my 95 frame. I checked out the video on you tube that Kelly (SOCAL) has done with Greg and was very helpful. Thank you Kelly! I ended up making my own tool using an old 18mm socket. Make sure the O.D. of the socket is slightly smaller than the bushing. Please note not all 18mm sockets are created equal and will vary on the outside diameter. I drilled out the center hole in the socket so I could slide in a 3/8" bolt to use as an alignment dowel for the bushing, cutting it a few inches longer than the socket and welded it to the top. The socket stayed on the outside metal edge of the bushing due to the alignment bolt and hammered it in place. Richard
Re: Replacing swingarm bushings
RR, I like the idea of the centering dowel to keep the socket in line. When my kids and I did the SA bearings on their ACE 100 it was a frustrating fight. Thanks for posting the tip, I know I'll use it in the future.
'72 Wombat (94)
'65 ACE 90? (Frame)
'66 Triumph Bonneville
'99 Triumph Adventurer
'66 Ace 90/100- Dirt only
'65 ACE 90? (Frame)
