Rebuild parts list
Posted: Fri Nov 18, 2016 9:07 am
This Winter I'm splitting the case and redoing my Wombat94 engine. The report from the PO about it being a fresh rebuild was a tad optimistic. I like to start gathering major parts in advance.
I know I will need a gasket, seal and bearing kit. We're going to pop the crank and redo it, so I'll get a crank kit. And shifter springs and parts, and kickstart springs and parts. Clutch I don't know about, though I plan to blueprint it, so I might get the plates/springs now and the bushings/shims/release parts while waiting for the shop work. Top end is new-- piston, rings and fresh hone-- so that will be reused.
This should cover the major, big ticket parts. Have I missed anything?
