spark plug fitment
Posted: Sun Oct 23, 2016 4:39 pm
Hi Everyone, here's the scoop. After a new top end install and oil injection system repair on a '75 Toad, I was running 32:1 premix during break-in period and to confirm proper injection operation. After run-in, I changed the plug (NGK B8HS) and have been running straight 92 octane nonoxygenated pump gas. It ran "too well" suggesting a lean condition. Leak-down test confirmed leak at the spark plug. I used the old stand by "finger tight + quarter turn" method on the install. After the leak down test, I applied the wrist torque wrench which properly seated the plug thus ending the air leak and restoring proper engine operation. The question at hand is: what is the best, safest way to install a spark plug to insure proper seating without overdoing it and compromising the function of the spark plug gasket? As always, thanks to all!
Best,
Matt
Best,
Matt
