6v headlamp bulb?
Posted: Sat Oct 22, 2016 11:05 am
by Neptune
Is it possible to still get one of these? For a Road Toad?
Re: 6v headlamp bulb?
Posted: Sat Oct 22, 2016 1:13 pm
by Bill2001
Strictly Hodaka should have one.
Posted: Sat Oct 22, 2016 2:23 pm
by Neptune
Huh. I'll look again...
Posted: Sun Oct 23, 2016 11:36 am
by Bill2001
Since I'm not planning night riding at first, and have a burned out headlight, This is what I've done as a temporary measure. I carefully removed the old bulb from the reflector/lens assembly and adapted an 1154 bulb to the reflector assy. Tbis is a "6v 1157" and is the brake/tail light bulb. It gives a 5w low beam (inadequate).and a 21w high beam (marginal). Not too good for night use, but if there is a requirement for "daytime headlights on" for motorbikes, it might seem to meet that requirement.
At a swap meet, I picked up a couple of 6v headlight bulbs of 25w/25w-- still not up to the 35w stock headlight, but better. I'm going to hunt up a couple of burned out headlamps and experiment. I'd like to be able to adapt an LED to 6v and fit it the the headlight.
Posted: Mon Oct 24, 2016 6:18 am
You can also get used ones from Bruce Young! Call him or email him! ; D Victor
Posted: Mon Oct 24, 2016 7:55 am
by rlkarren
I wrote a post some time ago with headlight replacement options for all Hodakas: http://www.hodakaforum.com/viewtopic.ph ... 4846#p4846
The ebay link is not active any longer but search the seller for similar items and you'll find many options.
I use a candlepower lens and I'm still using the same halogen H4 6v 35/35w bulb since I made that post. I have tested all the options I made in the initial post with great results. If you'd like to know more or have questions I can explain.
Posted: Mon Oct 24, 2016 1:39 pm
by Bill2001
That's right, Roger, your thread is here. I was thinking it was in a back issue ot the Hodie Club Resonator. It may be there, also.
I'm intentionally reinventing the wheel on this, looking at different options/solutions to the problem.
