Hodaka Decals
Hodaka Decals
Has anyone purchased & used the Hodaka decals on a tank? I'd like to see a picture of it if anyone has. Trying to decide if it's worth the $20 savings over the plastic emblems. So if you have a photo and/or comments about them let me know. ; D Victor
Re: Hodaka Decals
Which one? Is it the "part#logodecal" one? I've been looking for a helmet decal about that size
Re: Hodaka Decals
If you zoom in on the tank it had decals on it, they were there for the last 16 years. The bike was in storage.
Re: Hodaka Decals
Let me slip a decal/paint questipn in. Like Victor's Red Toad, I'm doing a custom red air cleaner covet to give a bit of a color accent on my Wombat 94. I'm using DupliColor red paint and DupliColor Clear Coat, and a Strictly Hodaka 2-color (red on white) Wombat 94 decal. I don't do clear coat plus decals that much. Would I paint the piece, apply the decal and then clear coat over it, or would the solvents in the clear coat affect the SH decal? I could apply the paint and clear and after that dries, apply the decal. But this wpuld leve the decal unprotected by the clear coat. Which way would be best?
Re: Hodaka Decals
Bill. If it's a plastic/vynal decal you can spray the clear right over it without issue. To make it easier to get the decal exactly where you want it, mix a tablespoon of dish soap ( I use Dawn) with 8 ounces of water an place it in a spray bottle which can be adjusted for fine spray. I used the one my eye glass cleaner comes in.
Lightly spray the area where the decal is to be attached. Put the decal in place on top of the soap/water droplets and fine tune your position. Then press it down and squeegee out the water from underneath. Use a lint free micro fiber rag to press the water out and secure the decal. Just don't press hard & work from one side across in the same direction until all the soap/water bubbles are out. Then let it dry well before clearing.
When I put clear coat on I usually build up 7 to 8 layers of clear. When there's no decals I wet sand with 1500 grit and then polish with a buffer $ 3M polishing compound.
But with decals under I don't wet sand & buff. I just clear and get it as smooth as I can during the spray process. ; D Victor
Re: Hodaka Decals
Good. It should work flawlessly, then.
Re: Hodaka Decals
I did this one the exact same way. Just don't over spray so it doesn't puddle and run! ; D Victor
