250sl rear sprocket help
Hodaka250SL
Post by Hodaka250SL »
What sprockets would work on a 250sl for both the front and rear
admin
Site Admin
Re: 250sl rear sprocket help
Post by admin »
There are a lot of options available
http://www.strictlyhodaka.com/70A-250-S ... s/2356.htm
Hodaka250SL
I went to but could only find the stock size for front and rear
Hodaka250SL
I need different size for the front and rear.
Call Paul direct and he should be able to help.
admin
Site Admin
Post by admin »
Thanks guys. I see exactly what you mean from the illustrated parts pages. I am working on it right now with updated products listings for the 250cc Hodaka sprockets. Hope to have it done today. If not will finish 1st thing in the morning.
Dan Killian we need to speak with you about pick up and delivery of more bikes please.....
Hodaka250SL
Thank you
admin
Site Admin
Post by admin »
Sorry I had meant to post this last night and thought I had... Don't get old.
http://www.strictlyhodaka.com/product-p/714622.htm
My forum will not allow me to post more than one link per post so if you use the "search" engine for the following code numbers you will find all the options.
Counter shaft sprockets 12,132,14 and 15 tooth
Rear sprockets 44,46 and 48 tooth options
714623
714624
714620
719250
719249
719251
Thank you
Hodaka250SL
Thank you that helps alot
