Carb Identification
Posted: Mon Aug 22, 2016 7:27 am
by Yamadaka
I want to verify if this is a 1976 Road Toad carburetor. I have it marked as such but wanted to make sure . 27mm ID engine side and air box side reads OD 43.9mm
Re: Carb Identification
Posted: Mon Aug 22, 2016 7:45 am
by Yamadaka
sorry I measured wrong
engine side....19.3 mm ID
airbox side.... 35.7 mm OD
sorry
Posted: Mon Aug 22, 2016 7:46 am
by racerclam
I don't think that Hodaka used an angled throttle cable fitting on the cap ???
Posted: Mon Aug 22, 2016 7:47 am
by racerclam
carb ID should be 26 I believe
Posted: Mon Aug 22, 2016 8:00 am
by Yamadaka
OMG
Let's try one more time--
engine side is 27mm I.D........34mm O.D
airbox side is 41.3mm I.D......43.5mm O.D.
Posted: Tue Aug 23, 2016 4:55 am
by dirty_rat
Sizes sound about right (carb was a 26mm, but could measure at 27mm at the outlet). What components are in it, ie: slide cutaway, needle jet, jet needle, pilot jet, main jet? And, as was mentioned, the Hodaka didn't come with an angled throttle cable tube.
Posted: Tue Aug 23, 2016 1:00 pm
by Yamadaka
Ok then I wanted to make sure before I put it up for sale
