I had a really tough time getting the fuel to flow thru the in line filter on this Toad. It seemed like there wasn't enough flow to move the fuel thru the filter & down into the carb.
I have the same in line filters on the Model 03 & the Ace, but those have more than 5" of fuel line to work with between the petcock & the carb filler tube. Any suggestions on how to set one up between the "T" joining the 2 petcock lines and the line to the carb would be appreciated. Victor
If fuel won't flow through the filter into a dry carb, first check the petcock for actual fuel flow without any hoses attached, then verify your float valve and inlet passages on the carb, as well as vent passages and overflows. Sounds like either very little fuel, or an air lock.
The filters with openings at 90 degrees to each other work nicely for some applications.
I found some 90* filters on eBay. 4 for $9.95. Placed an order and will try one when they get here! Good idea! Victor
Sorry I'm a bit late with these photos. Small and short inline filters can be found with a bit of searching.
I had one like your second photo. It's the type I talked about. Made connecting a bit of a bitch because there was too little tubing to connect in between, without making the fuel line flow in an upward direction. I think the 90* one is going to make a big difference in fuel flow. Victor
Jack. The fuel flows finexeuthout the filter. It just didn't want to flow well with the filter because it made the line buckle upwards after the filter. I think the 90* filter ends will give me what I need. And I know I need the filter! Thanks! Victor
I use the petcock on the left side only and plug the other side. Run a single gas line to the carb. Plenty of room for an inline filter.
Mike
Mike
Here's one thing you could try, Victor. In the typical orientation the brass "T" connector is positioned so that the two fuel lines enter the connector on either end of the cross bar of the "T" and the line to the carburetor connects to the upright of the "T". Try rotating the connector 90 degrees so that it is oriented like this "I--". In this configuration, the left petcock attaches to one end of the cross bar and the right petcock attaches to the upright of the "T". The other end of the cross bar connects to the carb via an in-line filter. This gives a more or less straight shot from the left petcock to the carb. Plenty of room to get that all-important in-line filter into the fuel line. Give it a go and see what you think.
I'll try that Matt, if the 90* filter doesn't flow OK. The nice thing about the 2 petcocks is you can leave one side off and use the other side as a reserve! Can make the difference between running dry or being able to go a bit further! Victor
When you say buckle do you mean a kink in the line or an upward turn? An upward loop of fuel line will not affect rate of flow. It may appear not to flow because of entrained air in the loop, but the question is not whether fuel appears to flow but whether it actaully does. The mass of a gallon of gasoline will overcome any number of upward loops in the fuel line as long as the tops of the loops are below the gas tank. It isn't necessary to remove all air from the fuel line because it is gravity fed. Do a flow test and see. Disconnect the fuel line from the carb and place it over a cup at the same height as the carb inlet. Turn on the gas. It should flow just fine as long as the line isn't kinked and the filter isn't plugged with gunk.viclioce wrote:Jack. The fuel flows fine without the filter. It just didn't want to flow well with the filter because it made the line buckle upwards after the filter. I think the 90* filter ends will give me what I need. And I know I need the filter! Thanks! Victor
Finished painting the correct pipe for the Green Toad tonight! Glad I got it done! This ones almost done now too!!! Victor
OK. I figured out I read the pilot jet incorrectly. It was indeed a #30 pilot & not the #50 I thought it was. So I cleaned the #30 and put it back in!
I also figured out I put the plastic floats in upside down last time and it stopped the float valve from opening!
That explains why she wouldn't start this past time & why there was no fuel in the bowl when I pulled the carb off again today! Argh!!! I need better copies of pictures in RT Owners Manual! Victor
OK! Turned the floats around, releveled the float arm and she purrs again! Now for a battery! Victor
I also have to say, that replacing the screw on the points made it much more secure and it stays tight now! No more slipping. Amazing what a single Screw can change! Victor
Need to go to the mailbox! I've been texted that my 90* fuel filters have arrived. I'll see how these work compared with the straight filters of past use. Hopefully the fuel will flow fine, AND clean! Victor
My nephew rode his bike around the neighborhood for about an hour for break in time. Poor guy! Had to smile the whole time!!! Victor
Got the pipe finished & mounted on the Green Toad yesterday. Also buttoned up some of the wiring. Hoping to have wiring finished today. And I still need a set of front turn signals if anyone has a set they can part with! Hoping to get the carb on today as well! :megreen: Victor
Mike
MIke! Yes!! They are!!! Can you part with them? If so, cost & shipping to 87507. My full address is
Victor Lioce
1088 Sunshine Way
Santa Fe, NM 87507
Priority Mail is fine! Victor
Victor Lioce
1088 Sunshine Way
Santa Fe, NM 87507
You have a PM.
Mike. Replied to your PM! Thanks!!! Victor
1977 Hodaka 80 dirt squirt
Does anyone have the mag coils resistance values and and how to test them also a wiring diagram for the 1977 Hodaka 80 dirt squirt. Thanks FB
Just about there, folks!!! Turn signals working, CHECK! Tail light working, CHECK! Brake light lighting up, just need Spring tension adjustment at front brake switch!
Last thing to check is the horn. Didn’t check to see if it honked before mounting it. I’ll pull the tank and straight wire horn to the battery. If it doesn’t work, I have a couple of spares. One of them should work!
Then it’s off to MVD for the title work & licensing! Yee Haw!!! Damn near done!!! Victor
Turns out the mounted horn didn’t work at all. Thankfully, I had a couple of spares! First one I grabbed honked when I connected to battery so I mounted it up and it honks with the switch!
My nephew is going to freak out when I tell him we can go to MVD!!! Victor
